Clicking Noise When Turning in 94 Accord
Old Apr 16, 2008 | 01:19 PM
rhdins's Avatar
Default Clicking Noise When Turning in 94 Accord
My 94 Accord LX has a clicking (clacking?) noise coming from the right front tire. It only happens when I am turning right, and about 75% of the time.
That driveshaft was replaced about 2 years ago because it was making the same noise, but it had a cracked boot and was pretty worn. I checked the cv boot on this one, and it's in good condition.
I read that someone had the same problem, and they figured that it was worn engine mounts allowing the engine to move when he was turning. Aside from that, does anyone have any other ideas to what it might be?
Old Apr 16, 2008 | 04:55 PM
deserthonda's Avatar
Default RE: Clicking Noise When Turning in 94 Accord
sounds like an axle to me..
and by the way the cv boot does not need to be ripped for an axle to be noisy ..
what is the warranty on the axle ?? some are lifetime warranty ... do you remeber where you bought it ??
Old Apr 16, 2008 | 05:04 PM
rhdins's Avatar
I'm pretty sure I got it at carquest. I have the reciept, I will have to check on the warranty.
Is it possible for the cv axle to be making that noise and not be bad, like it's just loose or something? Is it possible that it wasn't properly seated, and that is why it's making that noise. I would think if that were the case, if it wasn't in all the way, it would have gone bad alot quicker. When I hit a bump driving, I can hear a slight clank noise, like it's loose or something. I jacked up the car, and couldn't see that anything was loose or out of place.
Old Apr 21, 2008 | 08:57 PM
Drpepper's Avatar
I'm going for bad axle.
I replaced mine last year (94 EX) and a few months later it was clicking, clacking again. It was a bad replacement axle. And it was lifetime warranty. Too bad it would'nt pay for my extra labor.
I have heard that bad engine mounts could make the same noise. Can you eliminate that possibility?
Old Apr 21, 2008 | 10:24 PM
The way a CV joint is made, there's really no way for it to make the clicking noise without being bad. But it IS POSSIBLE for it to go bad without a torn boot.
huhdo
Aug 30, 2012 09:06 PM
samboka27
Aug 17, 2010 12:02 PM
jesselap
Dec 10, 2009 09:47 AM
jrcastro
Jul 2, 2006 12:06 PM
atwood
May 1, 2006 08:59 PM
