climate control panel thing semi-stuck
Old Dec 2, 2012 | 03:41 PM
sona1111's Avatar
Default climate control panel thing semi-stuck
hello, making a new thread because its basically unrelated. For a while the "foot" button on the control panel would not press (stuck) so like an idiot a pressed a little harder and it went in...lol. now none of the buttons will stick down, i have to hold them down and only the outer two. (full defrost and foot/face) actually produce the sound of the motor that changes the flow) The light for the "foot/defrost" one is stuck on. I took it all apart and it seems like their is not much i can do, their are little plastic blue things that seem to control this action but its so small i don't think i have a chance of fixing it.
That said, the only part i would need to replace would be the PCB board itself, as all the switches are attached directly to that.
1) does anyone know WHAT this is called? while i can find the outer plastic part of the bezel, i can not seem to find the electronic part anywhere.
2) does it matter if the new board has the A/C switch? (car has no a/c)
Old Dec 3, 2012 | 06:09 PM
Sounds like you might want to grab a spare unit from a bone yard.
Homestead'er
Feb 28, 2013 07:48 AM
davidn32
Jan 28, 2013 12:48 AM
S-F
Apr 21, 2011 10:28 PM
bug176
Jun 27, 2008 11:56 AM
greenbean
Sep 21, 2007 03:14 PM
