Climate/heater/temp control cable location in bay
Old Oct 26, 2008 | 03:52 PM
thewraith's Avatar
Default Climate/heater/temp control cable location in bay
Hi all,
My climate control on my 1995 accord ex w/h22 swap isn't working properly and I would like to trace the cable back to the engine bay. Can anyone post a picture showing me where this cable is located in the engine so I can adjust it or just permanently set it to heat till the winter is over? It's stuck on cold right now, the cable on the back of the in cabin is properly attached. Thank you!
meek
Old Oct 26, 2008 | 04:09 PM
finch13's Avatar
Default RE: Climate/heater/temp control cable location in bay
It doesn't go into the bay, it adjust the heater core in the cabin in the passenger foot well. You should make sure the dial is working correctly before you tear into the heater core. It's much easier to remove the dash trim than work down there.
Old Oct 26, 2008 | 04:20 PM
adealdds's Avatar
ORIGINAL: thewraith
Hi all,
meek
Its right behind/under the throttle body on the passenger side at the firewall.
it's easier to see it if you remove the air-filter assembly, the cable is clearly visible, attached to the heater valve which is itself attached to a large coolant hose...(see attached drawing for reference).
This seems to be a common failure with 5th gen accords, what i did with mine is disconnect the cable from the valve, spray some wd40 on the lever arm until it moved more freely than reattached the cable...
Good luck
[IMG]local://upfiles/18533/C5020553E6664F999A6553112ECBB219.jpg[/IMG]
Old Oct 26, 2008 | 06:34 PM
thewraith's Avatar
Thanks fellas. adeal, I did what you recommended and even swung it all the way to the right and left, no change in temp. i will try to check finches suggestion tomorrow as it's dark now. thank you both!
Old Oct 26, 2008 | 07:00 PM
adealdds's Avatar
ORIGINAL: thewraith
Sorry to hear it didnt work. Was the coolant in the hose near the valve warm enough ?
There are 2 hoses connected to the heater core and i guess the heat transfer comes from the coolant, so the heater might not work until the engine reaches a certain temperature...
I am not quite sure how the whole thing works, but in my case, the lever arm was kind of stuck and since i freed it, the heater started working...
Finch's idea is good, the dial **** tends to crack due to the excessive force applied and sometimes, the mechanism behind can also break, there are some plastic pinions there that can get out of sync..
this said, the heater should have worked even if the dial is dead, you said you manually adjusted the heater valve to an open position...
again make sure there is warm coolant reaching these hoses (carefully check if they are hot), that might be your problem (stuck hoses)....
Good luck anyway, let us know if you can fix it
93Accord2.2
Aug 5, 2013 03:08 PM
fjpthree
Jun 19, 2013 07:48 PM
cxm475
Feb 17, 2012 02:35 AM
honker3
Mar 18, 2008 11:49 AM
raf105
Sep 28, 2007 02:55 PM
