Closing the Moonroof '04 EX
Old Oct 17, 2011 | 05:29 PM
graymike's Avatar
Default Closing the Moonroof '04 EX
I seem to have to fiddle with the moonroof switch to close the moonroof . . . Do I understand correctly that there is no "automatic close"? It usually takes 3 or 4 tries to get it to the fully-closed position.
Thanks for any info.
Mike
Old Oct 17, 2011 | 05:57 PM
There is no automatic close; however, if you hold the switch it should close in one try. There may be a problem with the switch sending power to the moonroof close relay (e.g., corrosion, loose terminal for switch or relay, etc.) or even a faulty close relay. There are both an open relay and separate close relay, they are located under the headliner.
Old Oct 17, 2011 | 06:05 PM
graymike's Avatar
Redbull, thanks . . . it was operator error . . . i over-thought it.
anupm12
Jan 6, 2016 07:47 PM
92lx
Jul 22, 2012 08:32 AM
phatboyslim2012
Jun 21, 2011 08:58 PM
juststeve
Feb 26, 2011 07:52 PM
19Accord97
Mar 1, 2009 12:19 AM
