Clutch hydrolics
Old Nov 30, 2017 | 02:08 PM
Emena's Avatar
Default Clutch hydrolics
About a week ago my clutch pedal started to stick to the ground and felt spongy and later on that day my clutch was completely blown so I changed the clutch disc and PP put it all back together but when I went to test drive it the pedal would sink in without much pressure but felt stiff and nice. I can' move the car cuz it won't let me get out of gear please help I was told it's my clutch master cylinder, help me
Old Nov 30, 2017 | 04:23 PM
Did you bleed the clutch to remove any air from the system?
https://www.hondaaccordforum.com/for...-clutch-53115/
Old Nov 30, 2017 | 04:26 PM
Emena's Avatar
Yes I tried bleeding it but it felt the same way my brother said that everytime I press the clutch he can hear a noise coming from the clutch master cylinder but I don' see any signs of leaks
Old Dec 1, 2017 | 06:11 AM
Check the push-rod from the pedal to the MC, any couplings, anything to see what the noise is. The noise may be related or not, you don't know until you find the noise.
Pump the pedal without opening the bleed valve. Does the throw-out lever move?
MC may be bad, the piston-seals can leak back into the reservoir without leaking OUT.
Airhead
Feb 18, 2016 11:03 AM
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
