2009 Brake light problem
Old Nov 30, 2017 | 10:36 PM
Jessetiz's Avatar
Default 2009 Brake light problem
My brake light dosent beam higher when i press the brakes. All lights work such as headlights,turn signals,hazards,tail lights,reverse lights. But soon as press brake pedal it dosent do anything. Im assuming its a short somewhere because of a cheap phone car charger. I also drive a 1998 blazer that has the same problem i noticed days ago. I just drove the accord 2 days ago and only thing i used in both is car charger and bluetooth aux. Is there a relay or fuse to look for???
Old Dec 1, 2017 | 02:52 PM
First check fuse 13 for continuity (not burnt out).
Most likely fault is brake pedal switch not passing voltage. Need to test wht/blk wire on brake light switch (for 12V w/ brake pedal depressed.
If no voltage, a new switch is fix.
An open in wht/blk wire is also possible.
Old Dec 1, 2017 | 05:24 PM
Jessetiz's Avatar
Thank u. Went thru fuses they seemed all good. I went ahead and replace both bulbs and seems to do the trick. Eyes can be deceiving. They didnt look bad. They were.
badlt
Jun 1, 2016 09:21 PM
DannyJdm
Mar 28, 2012 08:03 AM
victorywhity
Mar 24, 2011 09:37 PM
98accord98
Sep 8, 2006 01:25 AM
