clutch problem on 05
Old Mar 25, 2007 | 04:33 PM
fabulous010's Avatar
Default clutch problem on 05
hi. i have an 05 4cyl coupe. my clutch seems to crunch when pressed all the way down. does anybody have the same problem? this one guy had the same problem with his tsx and the dealer changed his whole transmission and made it worse.... they couldnt figure it out. so i dont want to take it in. plus it doesnt do it all the time and doesnt really affect shifting..... is it normal???
Old Mar 25, 2007 | 09:23 PM
hondadude's Avatar
Default RE: clutch problem on 05
If you are still within the 3/36 warranty you should have the dealer check it out.
Where are you hearing the 'crunch', inside the cabin, or inside the engine compartment?
Old Mar 26, 2007 | 01:11 AM
deserthonda's Avatar
No if ,and ,or buts .......I would do as Dude suggested ,dealer all the way till they fix it to your satisfaction
Old Mar 26, 2007 | 06:32 PM
Briggz's Avatar
Almost A Senior Member
My '06 clutch used to let out a little squeak, maybe crunch, type sound when I let it out, but never pressing it down... and it only did it while I was driving... never while the car was stopped... Not sure if these are related or not...
Old Mar 27, 2007 | 06:08 PM
no its at the pedal. like i can feel the crunch. it doesnt do it all the time. and doesnt affect my driving. so i dont want to screw around. was just wondering if anybody experienced the same thing. im taking it to the dealership anyways to get rid of sum rattles. so maybe ill ask. thanx guys
Old Mar 30, 2007 | 03:06 AM
well lately its been squeeking. i thought maybe the pedal needed to be lubed??? lol anyways i took it in to the dealership and they said i need a new master cylinder. its covered under waranty. any input? well this improve my shifting or even braking?
Old Mar 30, 2007 | 03:47 AM
ORIGINAL: fabulous010
My input......have them do it,, it is free of charge .. and No , it will not improve your shifting , if all it was noise that you heard,, and it has nothing to do with the brakes
vetski179
Feb 24, 2015 04:26 PM
jkrueger2020
Mar 10, 2011 02:18 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
