Clutch problem
Old Dec 20, 2008 | 07:46 AM
danlowe
Default Clutch problem
Hi Guys,
My Dad has a honda accord 1.8 executive, year:2000. When you press the clutch pedal there is no resistance, it just goes loose. I believe for the last few days it was hard to get into gear but has now just given up. Any ideas or is it definately a new clutch required?
Thank you in advance.
Old Dec 20, 2008 | 08:02 AM
Default RE: Clutch problem
Symptoms indicate fault in the hydraulic clutch actuator, either the master cylinder or slave cylinder. Check the rubber boot on the slave cylinder by pinching and see if fluid emerges. If yes, the slave should be replaced. Master cylinder may leak from interface w/ the vacuum booster, or may be OK.
There's an FAQ under DIY on Page 5. Link appears damaged and may not be accessible.
Old Dec 21, 2008 | 03:48 PM
It may be fixed by simply bleeding the clutch fluid to remove air from the lines.
vetski179
Feb 24, 2015 04:26 PM
jkrueger2020
Mar 10, 2011 02:18 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
