clutch problem
Old Oct 27, 2011 | 09:23 AM
blkgrlcb7's Avatar
Default clutch problem
in my 93 cb7, when i go to push the clutch down, there is minimal resistance, then the pedal stays down.. i have to reach down and pull it back up. dont know whats going on. car is undrivable. please help?
Old Oct 27, 2011 | 10:39 AM
BoboZander's Avatar
I can help you with link > LINK < there is pictures of the 'problem' that often couse that kind of problem..good luck!
Old Oct 27, 2011 | 07:51 PM
There are a few other things to check....clutch fluid level is?
If full, check for the movement, or lack of, at the slave cyl.
A few more but we can start with these.
Old Oct 29, 2011 | 12:57 PM
blkgrlcb7's Avatar
what is the location of the slave cyl
Old Oct 29, 2011 | 01:59 PM
Down on the trans - it pushes on the clutch fork.
Old Nov 8, 2011 | 06:36 AM
blkgrlcb7's Avatar
ok well i checked the fluid level. it was 100% empty. i filled it. nothing happened
Old Nov 8, 2011 | 10:30 AM
Since there was no fluid, you have air in the lines and have to bleed the clutch. I think there is an ericthecarguy video on bleeding the clutch. Just google search that video. It might be on the video to replace the master cylinder.
Also, you have a leak that you need to locate. I would look below the master and slave cylinder for signs of fluid leaks.
Old Nov 9, 2011 | 09:53 PM
blkgrlcb7's Avatar
thanks
vetski179
Feb 24, 2015 04:26 PM
jkrueger2020
Mar 10, 2011 02:18 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
