clutch replacement
Old May 30, 2006 | 06:59 PM
lowdrag
Default RE: clutch replacement
I drained the gear oil on the transmission; where is the refill port?
Thanks so much
Old May 30, 2006 | 07:29 PM
sir_nasty's Avatar
depending on wether or not it is a manual or automatic it depends but on a lot of auto tranny's the easiest thing to do is just get a funnell and pour it down the dipstick tube.
Old May 30, 2006 | 07:34 PM
deserthonda's Avatar
ORIGINAL: lowdrag
Thanks so much
Above the axle, and a bit to the left, there is a 17mm plug, remove it and put in 3 qts of oil. USE ONLY ENGINE OIL .10w-30 10w-40 .. DO NOT use 80-90 w gear oil in honda trannies.
it will easier if you have a little pump to refill the tranny..
Old May 30, 2006 | 07:39 PM
sir_nasty's Avatar
I suppose I should have payed attention to the thread starter before I posted... for once someone posts all the info we need before hand and I don't even bother to look...... Old habbits die hard I didn't expect to see it *L*
Old May 31, 2006 | 03:21 AM
ORIGINAL: sir_nasty
.. It's ok sir Nasty ,, it happens to all of us from time to time ,,,
Old Jan 21, 2010 | 12:10 AM
anielsen's Avatar
why should you use motor oil instead of MTF on a honda?
Old Jan 21, 2010 | 08:21 AM
  #17
What year?
Honda manual trannys were designed to use engine oil instead of GL-4 gear oil. Then in about 1996 or so Honda started selling their own gear oil, HONDA MTF. That stuff is compatible with the older Honda manual trans, but it's NOT compatible with other trannys which need GL-4 or GL-5.
Old Jan 23, 2010 | 06:57 PM
  #18
anielsen's Avatar
its an 89
Old Jan 25, 2010 | 09:15 AM
  #19
I don't know what that wants; don't know what year they began calling for engine oil. Got an owner's manual? If it says to use 10w-30 engine oil, then you will see a bit better results from Honda MTF. If it says to use GL-4 or GL-5 gear oil, then you have to use that.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
yamahonda06
Apr 5, 2006 12:45 PM
