clutch safety switch during starting
Old Apr 19, 2014 | 07:02 PM
holmesnmanny's Avatar
the next time it doesnt do anything on the first try dont touch the clutch... tap the ignition switch side of the steering column .. if it starts its more likely the ignition switch contacts
if it still doesnt start tap the starter
if it starts not starting after driving it and letting it sit for a few minutes its likely the ignition switch contacts
Old Apr 19, 2014 | 07:27 PM
firefighter44's Avatar
Almost A Senior Member
Again i appreciate the advice but when i say i have already checked both the starter and ignition circuits and have ran the problem down to the clutch switch i have. I know quite a bit about automotive electrical systems and again i really appreciate your input. Also I rewired autos professionally for a many years and when i say i will splice the wires it wont be a "hack job". It will in fact look like it was meant to be that way. besides if i splice it i assure you even that would be temporary until I replace the malfunctioning part.
Old Apr 20, 2014 | 03:19 AM
Ok, fair enough. Good luck.
Old Apr 20, 2014 | 08:37 AM
Is it the switch or the relay? Hummm
YES, the manual trans cars in this gen have a starter relay.
You can jump/by-pass the inhibitor switch - as stated there are two on the clutch, one for starting one for the cruise control. If the issue is still there, well time to test/replace the starter relay.
tyndall
Nov 4, 2011 01:51 AM
louisvilleslugger
Oct 4, 2011 09:45 AM
pwcfan
Dec 10, 2008 09:31 AM
rflail
Jun 14, 2008 01:31 PM
inhot
Jun 7, 2008 07:23 PM
