clutch or tranny problem ?
Old Nov 13, 2008 | 09:46 AM
unR8ted
Default clutch or tranny problem ?
Hi all, i was wondering if i can get some help here. This last week end i was driving home at 5am and when i was like 3 miles from home. it felt like my gears popped out it just rev but wouldnt catch. i look down and it was still in gear so i tried switch gears and its all the same for all gears. so i had to push it to the closest house i knew. the next day i went and tried to see if it would work and nope this time i didnt even have to step on the clutch to change gears and still just revs didnt catch nuthing. now i think i drop my clutch. but just making sure could it just be a clutch spring. Or wouldi have to replace a whole new tranny and clutch. Winter coming and i need my car. also is there any way i can tell what to replace with out towing it to a shop. thanks,
its a 2000 accord coupe lx
manual tranny
Old Nov 13, 2008 | 10:22 AM
cjdm98's Avatar
Default RE: clutch or tranny problem ?
Could be slave cylinder.. or the actual cable.. Are you grinding gears trying to get it into 1st?
Old Nov 13, 2008 | 10:45 AM
unR8ted
when start the car i can freely change gears WITHOUT STEPING ON THE CLUTCH and there is no noise at all.
Old Nov 13, 2008 | 10:49 AM
falkore24's Avatar
I think it's the clutch or pressure plate. Either way, it's the same job. Could be the throw out bearing too, but I'd think that would make noise when shifting when the car's off.
Old Nov 13, 2008 | 10:50 AM
unR8ted
you think that maybe it could be that the shaft could of got out of place
Old Nov 14, 2008 | 04:05 PM
unR8ted
i was talking to a tech friend of mine and he said that before i start buying every thing. it couldbe my master cylinder is messing it up and not releasing the clutch so all i have to do is bleed the system out and that would work if thats the problem. i will try to do that later tonight and see the results hope its just that.
Old Nov 14, 2008 | 05:48 PM
unR8ted
well bleeding the clutch didnt help at all still the same.huh
Old Nov 24, 2008 | 09:18 AM
unR8ted
ok just got done putting every thing in yesterday and wow my old clutch was completly gone no more pads even let plus glad i got a new flywheel kus it was all ate up. also i dont think that your throw out bearing should come apart but it did. but yea putting in a new clutch flywheel. did the job and now my car is moving. love my new clutch only have to release about an inch and it grabs. dont even know how many times i killed the car. now i have to figure out why my vtech not working
MICHOASTYLE
Dec 17, 2012 09:35 AM
mkm31982
Oct 10, 2011 05:29 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
