Code for ABS light
Old Jul 19, 2012 | 02:17 PM
JJC's Avatar
JJC
Cool Code for ABS light
Can any one tell me what the code means for the ABS dash light flashing, once then 8 more times 1 - 8. It repeats then stops. This is when u jump the blue connector under the glove box. Thanks
Old Jul 19, 2012 | 02:21 PM
The list I have says 1-8 = "high-pressure system"
I don't know any useful troubleshooting for that, but it may be that the pump can't keep the accumulator pressurized or something. What are the symptoms?
Old Jul 19, 2012 | 02:45 PM
JJC's Avatar
JJC
First, I forgot to state it is an 96 honda accord, 4cyl, V-TEC, auto. As for the symptoms, it has none? I was looking for SRS code and the ABS flashed and not the SRS?? The ABS could just be low on brake fluid... OR was in the pass. It use to pump up when u first started it after setting. After topping it off it stopped doing this; I will
check it again. Thanks
Old Jul 19, 2012 | 04:46 PM
Look in the DIY section, I think I wrote up something a long time ago about bleeding the ABS systems. It might just be from air in the pump/accumulator system.
It might have been a stored code from awhile ago, so clear it and see whether it ever comes back. If it was winter time, you could mash the brakes to see if the ABS system works.
Old Jul 19, 2012 | 06:55 PM
ABS code 1-8 has following probably causes:
> Accumulator gas leakage
> Changed relief valve set pressure
> rear outlet solenoid valve late to close
> changed pressure switch set pressure.
Of these a leaking accumulator seems most likely.
Used modulators are readily available on ebay and car-part.com for <$50. It may be cheaper to try a used modulator unless you can confirm a leaky accumulator. you can check the acccumulator relief plug. There is a diagnostic in the Honda shop manual. See Online Manuals post in DIY forum for download manual.
Old Jul 20, 2012 | 02:30 PM
JJC's Avatar
JJC
To Jim Blake AND TexasHonda:
2 questions: How do u bleed brakes on a 96 accord (ur post just gives info on bleeding 98 and up).... and how do u reset /clear the codes on the ABS
Old Jul 20, 2012 | 02:45 PM
In my experience ABS bleeds itself unless the brake system is opened, in which case normal brake bleeding is req'd. Modulator pumps and recirculates fluid until modulator pressure is achieved. That said there is a bleeder on top of the unit.
ABS resets itself each time you turn system off/on. Codes will reset if fault is present.
Old Jul 23, 2012 | 08:03 AM
Up through 1997 the ABS system has it's own bleeding procedure.
See post #1 in this thread:
https://www.hondaaccordforum.com/for...systems-31259/
At the top, I mention that beginning in 1998 the system doesn't have it's own reservoir. But the drawing shows the earlier system with it's reservoir, and the bleeding procedure is in post #1.
93Accord2.2
Nov 7, 2013 07:10 AM
Custnam
Oct 28, 2012 12:50 PM
Stener75
Jul 25, 2010 08:21 PM
madsteez
Jan 18, 2009 07:43 PM
konradsa
May 29, 2008 06:56 PM
