Combination Switch
Old Aug 2, 2008 | 11:08 PM
Default Combination Switch
Where is the 20-pin connector that the shop manual talks about to test the combi. switch?
Old Aug 3, 2008 | 08:19 AM
Default RE: Combination Switch
Since I know you have a manual, I assume it wasn't there when you pulled the lower dashboard cover and knee bolster? Probably have to pull the steering column cover also.
Old Sep 14, 2008 | 11:00 PM
I found the combination switch connector. It was the blue plastic plug that had about half of the 20 pins filled. It was mounted left and below the steering column behind the knee bolster. There was another 20 pin connector (light green plug) in front of it, so that is why it was confusing.
The drawing in the shop manual didn't make it obvious which connector they were talking about. After I matched up the wire colors to the pins, it was pretty obvious which connector led to the combination switch.
outta-line
Feb 5, 2013 06:03 PM
Dead Zeppelin
Jul 13, 2012 08:36 PM
pirulino23
Nov 12, 2011 06:34 PM
mgabe2706
Dec 18, 2006 07:16 PM
Accordn2dis
Aug 26, 2006 09:36 PM
