04 Accord - Blinker is inconsistant. Is it the combination switch?
Old Jul 13, 2012 | 08:26 PM
Dead Zeppelin's Avatar
Exclamation 04 Accord - Blinker is inconsistant. Is it the combination switch?
Hello all,
My Accord just recently just started making a buzzing noise when you turn the signal on left or right (like a bee is in the cluster). Now it works sometimes and sometimes it doesn't, sometimes it is really fast, faster than a bulb out.
My first thought is the combination switch in the steering column but it does it with the hazards too. Is this still a combination switch? Is the combo switch and hazard button connected in the wire harness? Maybe a relay?
Thank you for your help!
Old Jul 13, 2012 | 08:36 PM
Sounds like a burned out bulb or the flasher relay in the driver's side fuse/relay box. If it is the flasher relay, it should be located in the upper right hand corner of the fuse/relay box.
Also see this thread regarding bulb or relay.
https://www.hondaaccordforum.com/for...rd-help-37853/
outta-line
Feb 5, 2013 06:03 PM
pirulino23
Nov 12, 2011 06:34 PM
PAhonda
Sep 14, 2008 11:00 PM
mgabe2706
Dec 18, 2006 07:16 PM
Accordn2dis
Aug 26, 2006 09:36 PM
