Coolant leaking where oil leak was?
Old Apr 26, 2013 | 01:39 PM
94ex915's Avatar
Almost A Senior Member
Default Coolant leaking where oil leak was?
Alright so I have had this oil leak for a while now and today I noticed that there is now coolant leaking where the oil was leaking from and the oil leak seems to have slowed. What could this be? I'm taking the car to my mechanic Monday to finally have this problem fixed but just wondering why would there be coolant leaking now.
Old Apr 26, 2013 | 02:52 PM
You might at least give a location where you saw oil and coolant dripping. We're not mind readers and can only respond to what is written. No description means no effective responses.
Old Apr 26, 2013 | 09:51 PM
94ex915's Avatar
Sorry I put this post up in a hurry. Its on the drivers side, looks like its coming from the timing cover. When I first took it to my mechanic he told me it could be the balancer shaft seal by just looking around the area. Weird thing about today is it really didn't leak oil but it leaked water which I have never seen before.
Old Apr 26, 2013 | 11:25 PM
My guess is that you have two leaks now. The oil leak is probably slower.
The oil leak is common from the shaft seals and o-ring seal under rear balance shaft gear behind the timing belt cover.
The coolant leak is likely from a failing water pump. Look to see if the leak is coming from a weep hole.
Regardless, you should have the timing belt, water pump, and the seals replaced. There are four seals. Definitely replace the o-ring and any leaking seal. You will get different opinions about replacing a seal that isn't leaking. Make sure a front balance shaft seal retainer is installed.
If you are due for the timing belt (every 7 years or 90K miles), then this is a maintenance item.
Old Apr 27, 2013 | 09:29 PM
94ex915's Avatar
Ya that it what I am assuming. It just seems like the oil leak has slowed down a lot. My mechanic quoted me $340 to change the timing belt, water pump, the balancer shaft seal and I believe some other seals.
Uberpippi
Jun 3, 2014 07:32 AM
afbryant
Nov 7, 2009 07:28 PM
jennelena
Mar 26, 2009 04:39 PM
ppoppome
Nov 17, 2008 03:50 PM
richomundo
Nov 20, 2007 09:16 AM
