cooling fan not on at idle for 93 accord
Old Jun 24, 2011 | 06:11 PM
Unplug that connector. Grab a thin paperclip. Bend it in a U shape. Stick the ends in the two slots on the electrical connector. As soon as you start the car, the fans should turn on.
FYI, that switch is #14 in the diagram below:
Old Jun 25, 2011 | 01:03 AM
gingle37's Avatar
Thanks again for the knowledge, will try in the a.m.
Old Jun 25, 2011 | 07:20 AM
gingle37's Avatar
OK, shorted out the connector and both fans come on at ignition, sweet! Does this prove that temp switch A is my problem?
Old Jun 25, 2011 | 11:55 AM
Almost 100%, the only thing would be sure that the coolant is properly blead.
Old Jun 25, 2011 | 02:22 PM
gingle37's Avatar
It was easier to bleed than I thought it was going to be. With temp switch shorted, the cooling fan now runs. Thanks to you all for the replies and really good info. Much appreciated!
paulmezick
Jan 10, 2012 07:19 PM
CDJDM07
Aug 24, 2011 09:51 AM
Custnam
Apr 14, 2011 05:08 PM
Custnam
Nov 9, 2008 04:33 PM
Equalizer
Feb 20, 2007 08:57 PM
