Cooling Fan Relay Burning
Old Sep 20, 2007 | 12:45 PM
allanzz
Default Cooling Fan Relay Burning
Hi all,
My Car Spec:
Honda Accord CA5 - M/T 1989
A20A2
My car cooling fan relay keep burning for the third time today within this month. All of my a/c and both radiator fanare working fine.Istill can drive my carwithout any overheating problem as long as my cooling fan relay are working. I can drivefor a long journey on the highway without any problemcos of the wind factor, surelymy radiator fan are not activate to heat up cooling fan relay.But i can't turn on my a/c all the timesince it will make my cooling fan relay burn fast.
Basic car radiator fan operation:
1) radiator fan auto activate when engine running hot and turn off itself when idle temp
2) with a/c on, all the radiator fan will auto activate all the time regardless weather your engine temp runninghot or not.
Hope will get some answer from the expert here..
Thanks all for the help
Old Sep 20, 2007 | 02:10 PM
Default RE: Cooling Fan Relay Burning
If the motor is in the process of burning itself up, it will draw excessive current thru the relay. I'm surprised it burns up the relay instead of blowing a fuse...
Check whether the motor spins nice without excessive friction. Check whether the fan blades are hitting the frame or the radiator or something like that.
Old Sep 20, 2007 | 02:31 PM
falkore24's Avatar
check the socket that the relay fits in. if there is a near short between the n.o. side and the n.c. side it could cause very excessive switching thus killing the relay .... if the short doesn't happen frequently, it could cause the problem that you describe.
Old Sep 21, 2007 | 04:01 AM
allanzz
ORIGINAL: JimBlake
Thanks jim for your answer, my fan working nicely without any problem at all, i'm surprised too my fuse also working fine.
falkore24, my relay socket got a little bit burn/melting due to excessive heat from relay itself, it only take me less thana minute to feel the heat from relay. It really too hot and could burn your finger if you touch it without using hand glove.
Someone told me that my car age are too old thus making most of my car wiring stiff and consume more ampere. He recomended me to change the wiring of that cooling fanrelay to rectify this. Since i can't open the back coverof the fuse/relay box itself due to permanent seal from the manufacturer, I do thinks to change a wholeset of my under hood fuse/relay box from the junkpart shop.(chop shop).
Can anybody give me someopinionon this?
Novaknowledgenow
May 30, 2013 08:58 PM
CDJDM07
Aug 24, 2011 09:51 AM
BOBBY-25
Jun 5, 2011 02:40 PM
greg05
Aug 31, 2009 05:32 PM
Equalizer
Feb 20, 2007 08:57 PM
