Cooling fans
Old May 12, 2017 | 05:37 PM
drummer1279's Avatar
Default Cooling fans
So an odd issue with my 2-door 92 DX. The radiator fans will kick on and off like normal in heat cycles, but they are not engaging when you turn the A/C/ on. Would that be the switch at the thermostat housing going bad??
Old May 12, 2017 | 09:08 PM
Nope. The switch is working because the fans kick on when your coolant hits the proper temperature.
Is your a/c compressor working? I'd probably start testing at the a/c diode as that provides a one-way path to ground on the green wire when you turn on the a/c.
Old May 13, 2017 | 08:36 AM
I do feel a slight "bump" when I turn the compressor on, yeah.
Old May 13, 2017 | 08:53 AM
where is that diode located?
Old May 13, 2017 | 09:59 AM
It is #2 on the diagram below, so near the condenser relay. #3 look like a rubber cap to protect it. It should have 2 blue wires going to it.
Please verify, because the shop manual I'm using is for non-US accords.
Flydog
Aug 30, 2007 11:24 AM
Cash4
Apr 7, 2007 12:47 PM
horgad
Dec 10, 2006 07:57 PM
91boz
Nov 29, 2006 03:35 PM
Fredi95EX
Jun 16, 2005 11:07 AM
