Cooling and Radiator Fans not coming on even with A/C switch to ON
here is pic of the new ignition coil, and a "green" connector underneath it. That was the one I removed and jumper. It is really buried in there. I think that is the correct one. Do the temp sensor/gauge have a "green" connector?
~pab
~pab
on my car the only green conections in the area are the switches, so in your pic it does look like the switch, have you recieved the new switch yet? if so does it look like the one in your car? if not id go to or call your local napa, and see if they have the correct part, they do have delivery options but i dont know if thats for shops only.
PAhonda ...
the temperature gauge does not rise, at least not the last time I drove it for about 20 miles (it stay pretty much below the middle). And the fans (neither one) comes on after driving (with the engine still running) or after shutting it off.
~pab
~pab
Start up the car, and let the engine idle.
When the engine coolant heats past ~194F, the fans should turn on. If the temperature gauge starts rising (past the middle mark), and the fans do not turn on, then you should worry about the temp switch A.
The fans will only turn on after driving, IF the coolant temperature is above ~217F and temperature switch B turns on.
