Crank but no start??
So i was driving and my car felt funny so i pulled over and restarted it and made it 100 feet and it died in the middle of the road. it will turn over and pop and spit and stuff but it wont start. is this the fuel pump, filter or what. fuel filter has never been changed, 205345 miles.
p.s. 1997 accord 2.2 non vtec
You need to determine if you are missing spark, fuel, or compression.
Turn the key to the II position, but do not try to start the car. When the check engine light does the bulb check and turns on for about two seconds, the fuel pump should turn on for two seconds. It makes a faint buzzing/whirling sound from the back seat, so turn off the blower, radio, etc... and listen carefully.
You may also want to check for engine codes. See the common diy thread on top of the gen tech help forum.
Do you have a timing light? Or an old spark plug?
im having a mechanic/friend of mine come tomorrow. yes the fuel pump runs. when i start it, i see a little bit of smoke coming from between the exhaust heat shield and alternator area that smells like burnt gasoline before the cat and i don't have a check engine light
9foaccord
Nov 22, 2010 08:46 PM
dimbee
Oct 12, 2007 02:52 PM
