Creaking noise
Old Apr 26, 2008 | 03:32 PM
tallgood's Avatar
Default Creaking noise
Over the last couple of months I have noticed a creaking noise coming from the rear suspension on my 99 4 Dr LX, 124000 miles. It has gotton worse. It happens over good smooth roads, so the suspension is not working too hard. I havenarrowed itto the sway bar. anyone else experience anything similiar. Ihave taken both brackets and rubber bushing off and greased them, no help.
Old Apr 26, 2008 | 03:57 PM
sir_nasty's Avatar
Default RE: Creaking noise
are you sure it's the sway bar and not the upper shock bushings?
Did you grease inside and outside of the sway bar bushings?
Can you re-create the noise by jacking up the car and moving the tire by hand?
another thing that it might be (not normally but...) is your hangars for your exhaust, a lot of exahust systems have rubber hangars and as it shifts a little bit those rub as well.
skoty
Jul 15, 2021 07:21 AM
initiator
Jul 15, 2021 07:18 AM
themanofRussia
Feb 12, 2012 09:20 PM
babbittd
Sep 28, 2009 08:18 AM
mtruism
Nov 3, 2006 03:13 PM
