cruise control failure, need HELP!!
Old Nov 2, 2006 | 11:57 AM
sunharry
Default cruise control failure, need HELP!!
I just got a 99 Accord LX V6 with 68K miles on it, however I noticed the cruise control is not working. The switch on the left of steering wheel can be turned on, just the buttons on the steering wheels is not responsive (the cruise light in the dash was also off). Another symptom is the D4 light in the dash is not working as well, can these two symptom lead to same cause? If I want to check fuse, could u guys tell me which one I should check? Sorry I do not have a manual.
Old Nov 2, 2006 | 02:10 PM
YeuEmMaiMai's Avatar
Default RE: cruise control failure, need HELP!!
are the rpms higer than normal? of so, check and replace your VSS if needed (Vehicle Speed Sensor) might want to check for codes
Old Nov 2, 2006 | 03:16 PM
sir_nasty's Avatar
with electrical problems I'd just go through and check all of the fuses, to test that D4 light you may need to pull the guages and make sure that it has power going to it when it's supposed to, might just be a burnt out bulb, However, if the cruise light doesn't come on and the D4 light doesn't work I'd say it's a fuse issue
Old Nov 2, 2006 | 03:30 PM
sunharry
I think the RPMs are normal, I just checked the fuse, it looks all right. somebody said it might be a dead speed sensor, but both my speed gauge and odometer works fine.
Old Nov 2, 2006 | 08:11 PM
deserthonda's Avatar
before all.......in the under dash driver side fuse box,,
chk fuse # 6 15 amps.. and fuse # 9 7.5 amps .. also underhood fuse box chk fuse # 47 20 amps..
Old Nov 2, 2006 | 09:12 PM
sir_nasty's Avatar
Desert, do you have most of the fuse locations in a form or image that we could post in a FAQ... I've got a few years covered but nothing newer than 94.... any thoughts?
Old Nov 3, 2006 | 12:06 AM
ORIGINAL: sir_nasty
unfortunatelly no..........i have alldata installed in the computer but i cannot copy anything
The Mikado
Aug 12, 2012 08:02 AM
nocode
Jul 23, 2012 05:53 PM
sdemasi
Oct 22, 2006 11:29 PM
aatc20
Sep 25, 2006 04:28 PM
deckerhonda
Jan 24, 2006 09:12 PM
