cruise control help
When you turn on the cc on the button on the dash the button lights up the cc on/off light in the cluster comes on but when you use the buttons on the steering wheel to set/accelerate/coast it doesnt work
Im thinking clockspring as the horn buttons also do not work.
Question is, is there anything else i should check first?
Where should i be testing at? i pulled the shroud around the colum and tested at the small black plug with 3 wires( lt green/red, lt green/blk, and blue/red) only have power to the blue/red.
Also tested at the plug at the blue box above the fuse panel (interior drivers side) and got nothing there as well on the lt green/red
Do you have the manual for this, check the Common DIY Threads post at the top of this section for where to get it.
LT GRN/RED should have battery power at the control unit when the "set button" is pressed....if not, IMHO do not assume the slip/clock spring just yet.....I'd test the switch next.
sdemasi
Oct 22, 2006 11:29 PM
aatc20
Sep 25, 2006 04:28 PM
