Cruise Control Problem
Old Jul 9, 2007 | 06:33 AM
waz2k5
Default Cruise Control Problem
I recently had my transmission fluid and timing belt changed as my 96K maintenance came up.
Driving home from the dealer I decided to use the cruise control, but it wouldnt work. It had previously worked the day before.
PROBLEM: I can press the CRUISE button and the light turns ON in the console and if I press the SET button that also turns on in the console, but when I release the gas pedal the car slows down and it appears that the cruise is not engaged.
My question is whether anyone knows if I should check anything before going to the dealership or whether it could be something they did when doing my maintenance. Thanks.
EDIT: I drive a 2003 4-cylinder.
Old Jul 9, 2007 | 05:38 PM
Chiovnidca's Avatar
Default RE: Cruise Control Problem
Maybe they left the vacuum line or wiring off the cruise control actuator?
Old Jul 9, 2007 | 06:37 PM
hondadude's Avatar
You should head back to the dealer and ask them to plug the cruise unit into the harness. [sm=exactly.gif]
tclkrull
Jan 2, 2013 03:31 PM
Dagonus
Mar 1, 2011 11:24 AM
houmic48
Oct 9, 2009 05:23 PM
franklin
Dec 25, 2007 12:49 PM
chronchameleon
May 12, 2006 12:47 PM
