cruise and power locks
Old Jan 6, 2013 | 04:17 PM
jessecolter's Avatar
Default cruise and power locks
Many thanks to the help with the brake lights, handy with the volt meter and wondering what to check for these:
I just had the cruise working by reconnecting one of the vacuum lines and shortly before that I replaced the 'compressor' but now nothing happens when I press accel/decel, no green light on the dash. I do get a green light on the cruise button itself.
Also trying to figure out why there's no response from the power locks, there's power at the fuse, I've tried disconnecting all but one lock at a time, and replacing some of the questionable lock assemblies along with both switches and still nothing.
Old Jan 6, 2013 | 08:50 PM
For the power door locks, do you hearing a clicking when you try use the locks? Either way, a relatively common problem that can occur on your generation Accords are due to cracked solder joints on the circuit board inside the door lock control module.
The door lock control module is located inside the driver's side door. Unplug the module, remove the 2 screws from the mount.
Gently pry the cover off, the printed circuit board should slide out. Check for cracked solder joints and resolder the joints.
Old Jan 7, 2013 | 08:35 AM
For the cruise control problem, try adjusting the brake light switch.
http://media.honda.co.uk/car/owner/m...l/422/13-3.pdf
Erik Faber
May 2, 2013 06:39 PM
Opballer
Feb 9, 2012 11:54 PM
Antarctica
Oct 5, 2010 08:33 PM
RuthlezzFL1P
Jul 13, 2008 08:52 PM
HAFAccord97
Oct 19, 2007 12:17 PM
