Cut the hood release cable!!
Old Sep 15, 2019 | 04:04 PM
rockhoundrob's Avatar
Default Cut the hood release cable!!
My son bought a wrecked 1998 Honda Accord. We removed pretty much everything from the front end.
Last thing we needed to do was cut the radiator support out. But then after we were done, we realized we forgot to remove the cable to release the hood and it was cut in 1/2.
Is there any way to splice the cable? Like solder it together with another wire with a 2 inch overlap?
Or some kind of small cable clamp?
Or do we really need to go to a junkyard and get one?
Old Sep 15, 2019 | 04:10 PM
The Toecutter's Avatar
Rock Auto sells a new one for around 12 bucks. Or you can look on E-bay for one. I think I bot a genuine Honda part from e-bay for 18 bucks shipped.
I wouldn't get a junk yard one, as the cable or the sheath might have been kinked (the problem I had with mine), and could make opening or latching the hood a royal PIA.
Old Sep 15, 2019 | 04:35 PM
I checked RockAuto and I see one for $5, but it says it's for a COUP.
Is it the same as for Sedan?
Reply
Old Sep 15, 2019 | 04:40 PM
Never mind... I went to Honda on line and both cables are the same
Old Sep 16, 2019 | 02:35 PM
Yeah, I would think they would be the same length, or within 2 inches of each other. hat cable is pretty long, so when you get it, you'll see what I meant by easy to kink.
Old Sep 21, 2019 | 01:57 PM
Got a Dorman cable from O'Rielys. Works fine! $12
PatBB
Sep 14, 2012 01:02 PM
minndogs
Mar 4, 2009 11:31 AM
katicbec
Jul 27, 2007 04:04 PM
Bullethole
Sep 11, 2006 01:04 PM
Bullethole
Sep 3, 2006 12:23 PM
