CV axle removal
Old May 11, 2007 | 12:13 PM
standupguy
Default CV axle removal
I have a 94 Accord EX I am trying to change the CV axles. I have everything loose that needs to be loose. The drivers side shaft is not wanting to move from the bearing hub. Is there a retainer somewhere i cannot see? The axle is not wanting to budge. I thought maybe the sensor from the anti lock sensor was holding it back no luck Any and all help is appreciated. Thank you in advance Brett
Old May 11, 2007 | 12:20 PM
Default RE: CV axle removal
This can be a problem. Shafts tend to sieze due to tight tolerances and rust/corrosion.
There isa special tool available to push the shaft from the hub. It bolts to the wheel lugs and pushes the shaft. Look under DIY Requests for a procedure and/or search for "CV shaft".
I have had success w/ using heat, a lot of PB Blaster and a brass hammer to hit the end of the shaft and break it loose from the hub. Don't use a steel hammer or you'll damage the shaft end. I did this once and had to grind the end of the shaft off to remove the shaft from hub.
Add your vehicle details to your signature line. One of the rules here.
fdte320
Oct 29, 2012 02:06 PM
deserthonda
Feb 23, 2012 09:05 AM
nixalot
Jan 25, 2007 02:02 PM
Alekat
Dec 29, 2006 11:38 PM
Alekat
Oct 16, 2006 10:51 AM
