CV Axle Replacement
Old Oct 9, 2014 | 01:41 PM
nrakid88's Avatar
Default CV Axle Replacement
Just realized this forum is for tutorials, not for questions.
Old Oct 9, 2014 | 01:50 PM
Most folks don't drain transaxle and don't have leakage. I've never had a problem w/ leakage.
Note, on installation and removal be sure to support the inside CV jt and pull straight out as you remove (after popping spring clip loose). This avoids loading the axle shaft seal and possibly causing a leak.
I have a 36mm axle socket (1/2" drive) that I've used on all mine. Air impact usually works nicely to remove. A 1-7/16" socket should work fine also.
Old Oct 9, 2014 | 01:53 PM
I moved your post about same time you reposted. I deleted 2nd duplicate post.
Old Oct 9, 2014 | 02:58 PM
nrakid88's Avatar
Wow, was not expecting that quick of a reply! Thanks for the help bud, off to the parts shop... hopefully this job will go smoothly
deserthonda
Feb 23, 2012 09:05 AM
1186gibriadams
May 27, 2007 09:15 PM
nixalot
Jan 25, 2007 02:02 PM
Alekat
Dec 29, 2006 11:38 PM
Alekat
Oct 16, 2006 10:51 AM
