CV Joint Popped out of tranny
Old Mar 1, 2007 | 08:49 PM
willyg
Default CV Joint Popped out of tranny
I have a 95 accord, 4cyl with manual transmission. I replaced the passenger side cv joint, bought at a national auto chain. Three days later im driving it and it makes a noise and quits pulling. I look under the car and see oil dripping from where the shaft goes into the transmission. I tow the car home and notice the cv joint had popped out of the transmission.
Could have the auto parts store sold me the wrong cv joint, or has anyone experienced this problem?
What could i look at that might cause this to happen.
I checked with the auto part store and they double checked the numbers and they say it was the correct part number.
Appreciate any help
Old Mar 1, 2007 | 10:22 PM
hondadude's Avatar
Default RE: CV Joint Popped out of tranny
make sure the circlip is on the end of the joint shaft, and when installing it make sure you feel the clip latch into its groove in the differential, also the joint seats all the way in against the axle seal.
You might want to check the seal to be sure it wasn't damaged when the joint popped out.
Old Mar 2, 2007 | 09:06 AM
willyg
Thanks for the reply
I did make sure of the circlip and also lighlty tapped it into place with a rubber mallet. I will have to keep an eye out for oil from the seal since ive already replace the cv joint.
I will put a few more miles on it and see if it happens again.
RobinsonRicer
May 21, 2013 03:04 PM
mack
Oct 31, 2012 02:50 PM
Diagram14
Mar 21, 2010 08:40 AM
DT98
Sep 15, 2009 01:24 AM
mogilir
Apr 1, 2009 06:57 PM
