CV Joint Problem
Old Jun 9, 2012 | 07:00 PM
tmounib's Avatar
Default CV Joint Problem
Is it possible that my drive shaft has extended in length? I am unable to re-install my knuckle because the upper and lower ball joints won’t align, as if the outer CV joint has been displaced outwardly. The inner boot looks like it is over stretched / somehow flattened. I don’t remember pulling on the axle shaft while removing the knuckle. Yes, I can feel a play in the axle, may be half an inch. How bad is this?
I am in the middle of a job of replacing my front wheel bearing 2-door 95 Honda Accord. I watched tens of videos and read DIY manuals. It is turning terribly wrong. Both right and left shafts are recent from 9 months ago
Old Jun 9, 2012 | 07:35 PM
crispin's Avatar
1) you should start your own thread instead of adding to one that is years old.
2) the axles can be compressed or expanded, I do not think it is possible to easily pull the ***** from the cup. What that means is that if the CV axle is extended further than you need it to reconnect everything you should be able to push on it and compress it shorter.
Also make sure it has not pulled out of the transmission.
Old Jun 9, 2012 | 09:44 PM
Remove the clamp for the inboard boot & look around. I bet the tripod bearing has pulled all the way out from the inner-driver.
Shocker
Aug 15, 2007 12:39 PM
hooey
Feb 20, 2007 11:27 AM
skareb
Sep 21, 2006 12:24 PM
di2iftwood
Jan 3, 2006 05:00 PM
77911S
Apr 27, 2005 09:51 PM
