Cylinder problems
Old Mar 16, 2013 | 10:31 AM
Gasman's Avatar
Question Cylinder problems
I have one cylinder that is not firing I've changed the rotor button. I can pull the spark plug wires off the other plugs and u notice a difference but when u pull the wire I'm having problems with NO difference. This is a 99 accord with 190,000 miles.
Are they any thing else I can check before I go any further.
Old Mar 16, 2013 | 10:55 AM
shipo's Avatar
Compression test would be the next thing on my list.
Old Mar 16, 2013 | 09:52 PM
V-6 or 4-cyl?
How's the tune-up stuff? Spark plugs, etc?
I'm with shipo on the compression test.
Old Mar 16, 2013 | 09:59 PM
maritimecd7's Avatar
compresion test would be my first step , if it comes back with low compresion check ur valve clearances on that cylinder , if there good then u have leakage around the rings ,
if the coprsion tests the same on all 4 cylinders the next step would be to see if u have fuel
Chris Jameson
Feb 19, 2013 06:39 AM
STINKA621
Mar 9, 2009 07:53 AM
Mr_Accord
Jul 11, 2008 08:36 PM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
KimberlyC
Apr 16, 2006 11:51 AM
