Cylinder problems
I have one cylinder that is not firing I've changed the rotor button. I can pull the spark plug wires off the other plugs and u notice a difference but when u pull the wire I'm having problems with NO difference. This is a 99 accord with 190,000 miles.
Are they any thing else I can check before I go any further.
compresion test would be my first step , if it comes back with low compresion check ur valve clearances on that cylinder , if there good then u have leakage around the rings ,
if the coprsion tests the same on all 4 cylinders the next step would be to see if u have fuel
Chris Jameson
Feb 19, 2013 06:39 AM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
