D4 light on, no start
Old Jul 30, 2024 | 12:24 AM
  #101
TrojanFan's Avatar
Do I take the radiator cap off then start the car?
Old Jul 30, 2024 | 09:46 AM
  #102
Yes, remove the radiator cap, then start the car. Hopefully you'll see air bubbles as the coolant is circulated. There are some good videos on bleeding air from the accord cooling system on youtube. Ericthecarguy had some useful ones on his channel I saw a long time ago.
Old Jul 30, 2024 | 11:29 AM
  #103
TrojanFan's Avatar
Thank you! I'll try that, fingers crossed. I'll update you. Hopefully this helps
Old Aug 1, 2024 | 04:34 PM
  #104
TrojanFan's Avatar
That did it! It's idling normally now. It sounds a little weird so I'll check that out. But it's 100 times better. I have to figure out why it's making a loud squeaking noise when I step on the brakes when stopping. I put on new brake pads and rotors that have never been driven on. Hopefully it's nothing
Old Aug 1, 2024 | 04:35 PM
  #105
TrojanFan's Avatar
Thank you for the the help!!
Old Aug 1, 2024 | 07:22 PM
  #106
kris_loehr's Avatar
What did you put on the back of the pads and where they ride in the mount.
Old Aug 1, 2024 | 07:35 PM
  #107
TrojanFan's Avatar
I put the red gel on them.
Old Aug 1, 2024 | 09:08 PM
  #108
You had a lot of stuff going on with that car, so I'm glad you worked through all of them. Southmainauto on youtube has some pretty good brake pad videos for hondas that migh help you out if you can't figure it out.
Old Aug 1, 2024 | 09:14 PM
  #109
TrojanFan's Avatar
Thank you. I'll definitely check it out
Old Aug 11, 2024 | 02:46 PM
  #110
TrojanFan's Avatar
It's running a little rough but there aren't any codes coming up. Can a faulty alternator cause the transmission to act up? When I put it in gear the N, R, and D4 lights wont come on unless I move the shift lever so it's between gears. So for example if I put it in D4 the light won't come on unless I move the shifter and hold it between D4 and N. That's what I have to do for N and R. But, D3, 1&2 come on like normal. Any suggestions guys?
