dash light fuse
Old May 10, 2012 | 09:39 AM
KelvinR's Avatar
Default dash light fuse
Can anyone tell me where the fuse for the dash lights are located on a 1995 accord ex?
Old May 10, 2012 | 10:45 AM
Tyler Joyce's Avatar
Either under the dash on the drivers side or under the hood. If not there its inside the console behind the radio. I remember seeing fuses back there but I forgot what they were for.
Old May 10, 2012 | 12:11 PM
KelvinR's Avatar
My fuse boxes don't have numbers on the covers
Old May 10, 2012 | 12:27 PM
It's the number 15 (15A) located in the under hood fuse box. But if the fuse is good, you may have a faulty dimmer. If it is the dimmer, get one from a salvage yard.
Attached Thumbnails dash light fuse-underhood-fuses.jpg   dash light fuse-dimmer.jpg
Old May 10, 2012 | 12:40 PM
crispin's Avatar
or bypass the dimmer as I have never thought the dash needs to be dimmed.
Bypassing it is super easy to do.
Old May 10, 2012 | 01:43 PM
KelvinR's Avatar
Thanks for the diagrams! Ill test this once I get home and give you.the info!
Old May 10, 2012 | 05:05 PM
KelvinR's Avatar
So I checked the fuse and its good. I also checked the dimmer and it actually dims the light which is arround the p for park on the dash.
But the gauges still arent turning on. What else can it be?
Old May 10, 2012 | 06:35 PM
When you say gauges not turning on, you mean the light around it? If so, it may be the bulbs.
Old Dec 23, 2024 | 01:05 PM
Hanzala's Avatar
Default Dashboard light not working.
I have Honda Accord 2012 .It is not in use since last six months i.e its in standstill condition .Today I replaced it with new battery n found the tail light and break light is continue glowing but there is no light glowing on the dashboard including car security light . All other interior and hazard light is working well except dashboard board light and car security light. Can anyone help me out through this .. n guide me to come out through this problem of my car?
spinplate1
Feb 20, 2020 09:21 PM
tvandentop
Sep 17, 2011 06:42 AM
bochincheboy
Apr 21, 2008 01:40 AM
ivrex
Dec 10, 2006 03:24 PM
