Dealer replaced fog light on 2013
Old Feb 1, 2016 | 07:59 PM
Bloodhound's Avatar
Default Dealer replaced fog light on 2013
My 2013 accord had fog light replaced at dealer because of broken mount bracket. Prior to changing in the daytime we have lights set on auto and fog light switch turned on. With this setting in the daylight both running and fog light dash light indicator were lit up as well as both running and fog lights were on. Now since the repair things light up differently. Want all to know this is only a daytime issue. Now since repair headlight set on auto and fog lights in on position we do not have dash light indicators on nor are the fog lights on. Only daytime running lights on in the day. As soon as it's dark headlights,dash indicators and fog lights come on. Guestion would be in daytime should dash indicators and fog lights be on if in a daytime running light situation.
Old Feb 1, 2016 | 09:51 PM
Fog lights are not supposed to be on when daytime running lights are on.
For the other difference, it is possible the auto light sensitivity was changed from the previous setting.
Refer to the owner's manual.
Automatic Lighting Control
When you turn the light switch to AUTO, the headlights and other exterior lights will switch on and off automatically depending on the ambient brightness.
You can change the auto light sensitivity setting.
Fog Lights
When the fog lights are on, the indicator in the instrument panel will be on.
They go off when the headlights turn off, or when the daytime running lights are on.
Old Feb 2, 2016 | 07:40 PM
Bloodhound's Avatar
Want to thank you for you imfo. I will check the settings.
maso5219
Dec 5, 2015 09:09 AM
Maddman
Apr 26, 2013 07:32 AM
ndp125
Feb 28, 2008 02:50 PM
Memory
Dec 4, 2007 06:58 PM
europeanboy
Aug 7, 2007 04:33 PM
