difference in 2.3 vtec motors
Old Aug 13, 2011 | 03:20 AM
accord99's Avatar
Default difference in 2.3 vtec motors
I have a 99 accord. 5 speed. Friend pulled motor out of her 2000 accord automatic. Any difference in motors. Things need to swap? I know flywheel. Have heard intakes are different. Both motors 2.3 vtec. Thanks.
Old Aug 13, 2011 | 06:45 AM
piggylover1985's Avatar
LEV or ULEV engine ? I put an 02 auto ULEV into my 99 5sp LEV engine not long ago, run good and no check engine light.
Old Aug 14, 2011 | 06:20 AM
accord99's Avatar
Not sure lev? Ulev? Not a green valve cover motor. 23A.
Old Aug 14, 2011 | 07:36 AM
They have f23a1 LEV 150hp, f23a4 is ULEV 148hp both Vtec and f23a5 135hp which is not Vtec.
Old Aug 15, 2011 | 04:15 PM
Not sure if 2000 had coilpacks instead of a distributor??? If so you might have to swap distributor & other sensors over from your old engine.
Old Aug 15, 2011 | 04:25 PM
I don't think they used coil pack in the f23a engine 98-02.
Old Aug 15, 2011 | 07:59 PM
accord99's Avatar
Ok, the motor in my 99 accord 5 speed says F23A1. The motor I got from friend out of here 2000 accord automatic says F23A1 also. Same motor.? Somewhere I herd automatics had smaller throttle bodies. Both motors look the same. Both have distributors. Other than flexplate to flywheel. Anything else different?
Old Aug 16, 2011 | 11:31 AM
I don't think the throttlebody is any different, but you could measure the bore diameter.
Your flywheel bolts are longer than what's used for the (thinner) flexplate, so use the long bolts.
I don't know of any other difference.
Old Aug 16, 2011 | 08:01 PM
g22cd5's Avatar
Supper Moderator
Not sure on the economy engines. But I know the performance engines h22/f20b ect. the autos ALWAYS had a smaller TB than the 5 speeds. I think it had something to do with the power output b/c of the transmission falling apart.
Old Aug 16, 2011 | 08:37 PM
The intake manifold and throttle body part number for automatic is different than the one for manual.
firefighter18170
Aug 19, 2008 08:45 PM
white98accordex
Jun 10, 2008 03:05 PM
quiCk paW 07
Mar 2, 2008 09:04 PM
gravey86
Jan 13, 2007 02:03 AM
