Difficulty selecting D3
Old Jul 24, 2007 | 09:12 PM
rexsquared
Default Difficulty selecting D3
Hi Folks,
2001 Accord EX V6 A/T ~61K miles.
D3 does not engage nor does indicator light up unless additional rearward pressure is applied to shifter. All other gears can be engaged without problem. I checked the shift cable adjustment and it is fine. When I had the console apart I noticed that to get the D3 light to light I had to pull the shifter rearward until there was about a 2 mm gap between the ****er mechanism and the retaining tooth. Could be the transmission range switch be the source of the problem?[/align]
Old Aug 17, 2008 | 12:44 PM
rexsquared
Default RE: Difficulty selecting D3
I thought I'd give this a bump. Could this be caused by a worn/defective transmission range switch?
Old Aug 17, 2008 | 11:20 PM
If the tranny doesnt actually engage the proper gear, then it sounds likethe shift cable adjustment.
Old Aug 18, 2008 | 05:36 PM
rexsquared
Thanks for the reply. I checked the cable adjustment and it was spot on. All other gears can be selected and engaged. After I checked the adjustment I thought that maybe, due to a little wear, I need to slightly favor the adjustment one way or the other. Well I got D3 to light up but no other gear could be selected!
razingkane
Feb 11, 2014 12:30 PM
JOE.G
Sep 3, 2013 10:59 PM
chanonope
Aug 16, 2011 11:50 AM
Honda626
May 14, 2011 08:20 AM
Gne3DO
Sep 25, 2010 08:06 PM
