dimmer lights and tail light go out & keep blowing a 15 amp fuse.
Old Aug 13, 2012 | 05:23 PM
alyssapie's Avatar
Question dimmer lights and tail light go out & keep blowing a 15 amp fuse.
im having trouble with my dimmer lights they have completly gone out as well as my tail lights, i replace the (15 amp) fuse and they seem to work for about 30 mins then the fuse blows, while the dimmer lights work i have to mess with the switch to get them to stay on of course untill the fuse blows. Anybody know were to start or have suggestions how to fix this.
Old Aug 13, 2012 | 05:59 PM
You probably have a short in a wire or electrical connector. A short is an accidental connection of a wire to ground or to another wire.
What year and model car is this?
It could be at the combination light switch, the dimmer switch, the wiring, etc. Check the wire insulation, electrical connectors, and switches.
Was there anything recently done to the car, like adding an aftermarket stereo, etc.?
Btw: Welcome to the forum.
Old Aug 13, 2012 | 06:12 PM
alyssapie's Avatar
its a 1995 honda accord, i havent had anything done accept get tires a couple months ago i did have a radio put in but that was in 09 and this prblem just started about a month ago.
Thanks
Old Aug 13, 2012 | 06:23 PM
Let us know if you find anything or need additional info.
Old Aug 13, 2012 | 06:30 PM
alyssapie's Avatar
Me and my dad or My boyfriend and dad are going to check out the wires and things
Thanks and i will
Old Aug 13, 2012 | 08:56 PM
Time_Will_Tell's Avatar
Default trouble with dimmer light and tailights...
I also had a related poblem except it was with the side marker lights and my tail lights, atually all the interior and exterior lights excluding headlights... It was an electrical short on my driver side parking light it had rubbed against the fender long enough to actually puncture the rubber sheathing on the wires and short out on the fender itself.. so chances are its a short, and u need to find it! Good luck!
Old Aug 13, 2012 | 10:58 PM
alyssapie's Avatar
thank you, i kinda thought it was a short but im no pro lol
rjaccord
Jun 17, 2017 12:07 PM
biggin
Apr 15, 2014 09:15 AM
Uberpippi
Feb 1, 2013 10:09 PM
moddisonj
Dec 18, 2012 10:56 AM
Da Flash
Jun 6, 2011 10:03 PM
