Does my 91 EX have OEM foglamps?
Old Nov 30, 2007 | 03:59 AM
19Accord91EXlady's Avatar
Default Does my 91 EX have OEM foglamps?
Just a question..Does my ex have Factory Fog lights?
Old Dec 5, 2007 | 08:42 AM
cheggie's Avatar
Default RE: Does my 91 EX have OEM foglamps?
No - this one does not have OE foglamps. I put them on my '91, and it was pretty simple. They fit under the front turn signal lights. If you look there is a little outline for them in the black plastic. The OE's look awesome, of course they were designed for the car. For a clean install, find a set of 90-91 OE foglamps, with the steel brackets, and at least a wiring pigtail. You might want the OE button for the dash - it goes right next to the hazard flasher. Again, you have a little punch out to accomodate it. It's not necessary if you'd be happy with a generic parts store switch. I reproduced the wiring with a relay and fuse, by using a generic foglamp wiring kit from one of the auto parts stores. It had enough wiring, loom and the relay and fuse holder to make the job simple. I have pictures and a diagram if you want them.
Aug 9, 2006 12:34 PM
GodMachine
May 12, 2006 01:14 AM
Green_Accord
Apr 2, 2006 03:44 PM
emaxxman
Mar 8, 2006 09:12 PM
TedsF23accord
Jan 15, 2006 08:57 PM
