Door Handle Coming Loose
Old Dec 8, 2006 | 03:13 PM
wayneboard2's Avatar
Default Door Handle Coming Loose
OK so the drivers door handle is coming loose. It still works fine, but some sort of clip or bolt has come off of one side of it and I can't stand it anymore. Pretty soon it will break the other side. Do I have to remove the entire interior section of the door ti fix this or is there another way? A pic is below so you can see what I'm looking at. Thanks!
[IMG]local://upfiles/6885/11B2D48F85D641F4B0DA8050C782BAA1.jpg[/IMG]
Old Dec 8, 2006 | 03:17 PM
sir_nasty's Avatar
Default RE: Door Handle Coming Loose
Yes you have to remove the door panel on the inside... it's actually fairly easy to do.... what year/model is it?
Old Dec 8, 2006 | 03:21 PM
1997 Honda Accord SE 4 cylinder Automatic. Thanks for the quick reply!
Old Dec 8, 2006 | 03:30 PM
sir_nasty's Avatar
search the forum for door panel removal, it's pretty simple actually, there is a screw in the upper right corner, one inside the armrest handle (where you pull the door closed) and one going through the top right hand part of the armrest into the door, then one last screw behind the door handle, all of these are covered with little annoying plastic covers, remove them, remove the screws, pop off the door handle assembly (inside the door) pop off the mirror cover in the upper right hand corner, then start at the front, slide your fingers in underneath the panel and work your way around to pop off the clips that hold it on and then it should lift up/off!
Old Dec 8, 2006 | 03:50 PM
hhhmmm.....lol...maybe I should of clarified something; when it comes to mechanics, I'm a nitwit.
I will do a search as you suggested but I sure hope the process comes with pictures! lol Thanks again.
Old Dec 8, 2006 | 03:59 PM
OK, I did a search and I wonder if you can help this old newbie out a bit. Do you happen to know of a link or site that shows pictures of this process? Not ever having done this before, I'm a bit hesitant to just start unscrewing things. Thanks!
Old Dec 8, 2006 | 04:07 PM
sir_nasty's Avatar
here is a how to with a picture that I wrote up a while back for power windows but it should help immensly....
https://www.hondaaccordforum.com/m_16927/tm.htm
This shows two of the screw locations too...
https://www.hondaaccordforum.com/m_16211/tm.htm
questions?
Old Dec 8, 2006 | 04:19 PM
thats very helpful thank you! One more question and I think I'm good to tackle this. What type of screw are these? Philips or the star type?
Old Dec 8, 2006 | 05:47 PM
sir_nasty's Avatar
Phillips, fairly straightforward job, just be sure you get that door handle section out or it will snag
pstoric
May 20, 2015 06:45 AM
JPodAccord
May 26, 2012 05:10 PM
Motman Idaho
Mar 22, 2012 10:20 PM
hhrumph
Mar 18, 2011 08:19 PM
tonyw85
May 5, 2008 05:29 PM
