Spark plug coming loose.
Old May 5, 2008 | 04:07 PM
tonyw85
Default Spark plug coming loose.
I own a 95 Honda Accord. About 2 months ago, as I was driving, my car suddenly started rumbling. I pulled over and noticed that one of the spark plug connectors was loose (about 0.7 cm higher than the others), so I pushed it back in, and the car ran fine again. All was well until yesterday, when the rumbling started again. Same problem, same fix. Today, after driving for about 10 minutes, it happened again. I yanked the whole spark plug thing out, and noticed that it was coated with oil. The other spark plugs have some oil on them too, but not as much, and they don't get loose. Any ideas what's wrong and how to fix it? Thanks.
Old May 5, 2008 | 04:46 PM
00AccordLX5spd's Avatar
Registered User
Default RE: Spark plug coming loose.
Sounds like you need to replace the spark plug tube seals and you might as well replace the valve cover gasket while you're at it. here's a DIY: http://filtsai.com/accord/valve_cover_gasket/index.php
Old May 5, 2008 | 05:01 PM
Those seals would explain the oil, but maybe not explain the plugs popping up.
Check your spark plugs haven't worked loose over time (leaking compression which pushes the plugs up). Or maybe just replace the spark plugs if they'renearlydue?
Old May 5, 2008 | 05:29 PM
finch13's Avatar
Let's hope they're the upper seals and not the lower...
I don't know if you could stick a needle nose pliers in the plug and pinch the... thingers... closer together. Worth a shot.
pstoric
May 20, 2015 06:45 AM
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
offroadTRD
Jul 3, 2009 06:38 AM
wayneboard2
Dec 8, 2006 05:47 PM
