Door Lock problem Honda Accord 2005
Old Apr 19, 2014 | 04:18 PM
  #21
rodrigo7x's Avatar
Hurray!!! I found a newer post on how to do the programming and this one works for me:
How to Program Factory Honda Acura Remote Key Fobs: 10 Steps
saved me some bucks. So everything works great except the rear driver's side window. I will take the panel off and see if I by mistake left something unplugged and post back if I get any good results or to let anyone reading this post know how it all ended up.
Hope this thread helps someone else too.
Best Regards!!!
Old Apr 20, 2014 | 07:45 AM
  #22
Somehow I missed the "newer" posts here but it sounds like you have it figured out.
With the panel off, hope you find an easy fix. If not be sure to test the motor while there. Also, haven't seen this on the newer Accords but some of the older ones had an issue where the "connector plug" in the door jam would work loose.
Old Apr 19, 2015 | 06:32 PM
  #23
november33's Avatar
Default Battery Reset worked for me
Was having the issue with the FOB not unlocking the driver door. Horn would not beep on the second key FOB click as well. Performed the battery disconnct reset and like magic the car responds to the FOB. Had already just replaced the actuator which did not fix the problem. 2005 V6 sedan.
Old Aug 30, 2018 | 05:35 PM
  #24
smoke's Avatar
Default I have to come very close to my Honda Accord 2006 before it unlocks
Hello everyone,
Been having this issue for quite a while now, i have to come close to my car, driver side or inside (and press the key fob )for the car to unlock, please what could be the problem? help.
Old Aug 30, 2018 | 07:20 PM
  #25
Have you tried a fresh battery in the key fob?
How about the other things earlier in this thread?
Old Aug 31, 2018 | 01:02 PM
  #26
smoke's Avatar
I av change the battery on the key fob many times and my car battery too, about 3 times, still problem remain d same.
Old Aug 31, 2018 | 03:37 PM
  #27
Seanjordan20's Avatar
It seems you will have to get a new master switch if you feel you have exhausted all options
Old Aug 31, 2018 | 03:57 PM
  #28
smoke's Avatar
Where can i locate HONDA ACCORD key receiver?
Old Aug 31, 2018 | 04:38 PM
  #29
Are you taking about the part that receives the signal from the fob? If so it's the master switch. The part on the driver side with all the window buttons.
Old Aug 31, 2018 | 05:43 PM
  #30
smoke's Avatar
You mean this?
pmay805
Mar 16, 2015 10:41 AM
HateThisHonda
Sep 19, 2013 09:45 AM
bhollehday
Mar 20, 2013 07:18 PM
Doublel
Mar 11, 2013 07:57 AM
bczupryna
Feb 11, 2006 05:50 AM
