Door locks not working help!
Old Feb 21, 2012 | 02:44 PM
jdarrah66's Avatar
Default Door locks not working help!
hello all i havee a 97 accord se. My door locks are not working properly. I do have a keyless entry which doesn't seem to be programmed right. I can unlock my driver door with the remote keyless entry and by the switch on the door....however i cannot lock it along with any other door with any of their switches . any ideas???
Old Feb 21, 2012 | 07:24 PM
Two things. Drivers door closed, if you use the drivers lock switch to lock and unlock the doors what happens.
All doors unlocked and closed, use the drivers side outer key cyl to lock the doors. What happens.
Old Feb 21, 2012 | 08:33 PM
jdarrah66's Avatar
with the drivers door closed and using the driver door switch it will unlock just the driver door and nothing happens to the other three doors.
with all the doors closed and unlocked when i use the key it will only lock the drivers door.
hope this helps!
Old Feb 22, 2012 | 06:09 PM
Ok, I'm leaning towards the keyless entry control unit....however the manul I have only covers this on the 95 wagons....so if anyone has a better one please chime in.
Do you have a volt meter. on the pass door lock actuator, when you use the drivers side switch to unlock, the pass side actuator should get 12v on the YEL/RED wire, does it? EDIT: also do the same with the pass side lock switch, sorry left that out.
camman
Nov 20, 2013 01:15 PM
paulson524
Aug 10, 2013 10:13 AM
paksen
May 18, 2012 08:07 PM
Antarctica
Oct 5, 2010 08:33 PM
firechicken
Feb 2, 2010 03:20 PM
