driver seat is reclined way too much!
Old Sep 15, 2011 | 05:39 AM
jackfast's Avatar
Default driver seat is reclined way too much!
91 accord with 'dial ****' for seat adjustment. the problem is; i cant turn it any more to raise the seat to a more upright position. i dont know if it is turned all the way, or just stuck, but i dont want to break the ****. any ideas?
Old Sep 15, 2011 | 06:28 PM
**** or lever? I thought the ****-twist-was for the lumbar support.
I thought the lever was for the recline.....
Old Sep 16, 2011 | 12:55 AM
Honda_Lady's Avatar
what Poorman212 said. the **** should be for lumbar support and the lever should be for adjusting how far it's reclined. i have a 92 and it should be the same for your 91 i would think.
Old Sep 19, 2011 | 06:16 AM
jackfast's Avatar
you are both correct about the ****. the problem remains however; the lever only 'sticks' in the recline position. i guess i will take the seat out and see what is going on.
Old Sep 19, 2011 | 05:00 PM
Honda_Lady's Avatar
perhaps the lever and seat back need a tiny jiggle to get it to latch sitting more upright. it has notches for certain seat back positions. maybe it needs some cleaning (though i am not sure how one would go about cleaning it, never had to do it with mine) good luck figuring it out and let us know when you have gotten it to work
Old Sep 19, 2011 | 05:35 PM
bigpat's Avatar
Almost A Senior Member
You should be able to pull and hold the lever up while not sitting on the seat, and the seat back will move forward into the steering wheel. Now let go of the lever and push the seat back into the first upright position/locked. Lift and hold the lever to adjust the seatback to your desired setting and let go of the lever. If this isn't working for you, then there is likely a piece of linkage or spring in the mechanism that isn't right.
Old Sep 20, 2011 | 09:30 AM
jackfast's Avatar
that is the problem; the seat only reclines to one position (about 135degrees). i guess i will remove the seat and take a look at the mechanism.
RobinsonRicer
Dec 22, 2013 08:42 AM
mthomson
May 14, 2013 07:01 PM
Sadus
Sep 6, 2011 11:29 PM
Custnam
Apr 14, 2011 05:08 PM
NICK63
Nov 2, 2009 11:57 AM
