driver's power door lock problem - 2003 Accord
Old Oct 18, 2008 | 06:12 AM
vfchris
Default driver's power door lock problem - 2003 Accord
I just bought a 2003 Accord LX. The power door lock on the driver side does not lock or unlock in response to the remote control. I can see it move just slightly while I press the remote buttons, like it is "trying" to work, but it just doesn't seem strong enough. It operates fine manualy (putting the key in the hole and turning it), so it doesn't seem to be binding. Is it possible that the power solenoid is "weak," but not completely failed?
I would appreciate any thoughts and/or experiences.
Thanks,
Chris
VFChris@aol.com
Old Oct 20, 2008 | 12:40 PM
Default RE: driver's power door lock problem - 2003 Accord
Its also possible there is a loose/broken linkage between the lock motor & the actual lock. I think you have to remove the inner door panel & look around.
Old Oct 20, 2008 | 12:42 PM
finch13's Avatar
x2^. The linkages are separate. Any grinding noises?
Old May 16, 2010 | 05:59 AM
Plumcrazebody's Avatar
my moms accord is having the same problem. any suggestions?
Rob2000AccordLX
May 9, 2014 06:23 PM
jza240sx
Apr 30, 2013 04:14 PM
accordgary07
Apr 10, 2011 07:47 AM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
Raptors
Sep 15, 2008 09:43 AM
