E brake light 94 ex sedan
Old Feb 5, 2007 | 04:22 AM
HuYnHness's Avatar
Default E brake light 94 ex sedan
alright so my dad's car is a 94 ex sedan and most of the time the e brake light is on even though the e brake is down. this in turn (i heard) shuts off the abs because the abs light turns on too a lil bit later. can anyone help?
Old Feb 6, 2007 | 02:27 AM
deserthonda's Avatar
Default RE: E brake light 94 ex sedan
chk to make sure there is planty of fluid in the reservoir and that master cylinder is not leaking ?? also take a look at the abs modulator i have seen a bunch of them leak.. and on the final note,, you need to pull the abs code and post it here
Old Feb 7, 2007 | 02:13 AM
HuYnHness's Avatar
im pretty sure there is plenty of fluid in the master cylinder i dont really know how to check the modulator and how do i check the abs code?
Old Feb 7, 2007 | 02:19 AM
under the glove box.. rt side of dash, there is the sc connector ,, it is a 2 wires connector not plugged to anything, it is next to a 3 wire connector not plugged to anything either .. they might be hooked into a green plastic cap,
You need to jump the 2 wire connector together with a paper clip,, turn ignition switch on and on the instrument cluster cound the sequence of flashes of the abs lite .long and short
1 long short pause 2 short is code 1-2
1 long longer pause 1 long is code 1,, code is repeating itself,, etc etc .
as for the E- brake lite being on , if fluid is full it might be a bad master cylinder cap , i have seen a bunch of them act up
Old Feb 8, 2007 | 02:58 AM
HuYnHness's Avatar
ill try that when i have some time
high school student who likes to procrastinate homework haha
thanks desert
DannyJdm
Mar 28, 2012 08:03 AM
victorywhity
Mar 24, 2011 09:37 PM
drtysohc
Feb 3, 2008 03:23 PM
98accord98
Sep 8, 2006 01:25 AM
