ECM control and interface(fuel pump relay module)
Old Feb 10, 2013 | 11:35 PM
metaluna's Avatar
Default ECM control and interface(fuel pump relay module)
HELP! HELP! HELP!
I need documentation refering to how the ECM controls the fuel pump relay module
It appears that it grounds the coil for the relay that drives the fuel pump.
but A16 is floating not grounding pin 8 (relay coil)at that point I'm lost
I breadboarded the module and I grounded pin 8 and it works fine.the computer is'nt giving me the ground needed .any help would be most welcome.
I do some some electrial engineering background,so I should be able to follow along.
I Thank You For Your Consideration
Gregory F Rummans
Old Feb 11, 2013 | 09:51 AM
I moved your thread to the General Tech Help section.
Please read the forum rules regarding where to post. Do not post help questions in the DIY section.
In addition, please include the year, make, etc. for the vehicle.
Old Feb 11, 2013 | 11:22 AM
Back when I still had the wiring drawings for my 98 Accord, I think there were several ground wires from the PCM. It was never spelled out, but it seems logical that they were separate grounds for different functions.
Say for example most ground wires were OK, so the PCM itself works fine. But an open ground wire that provides the "other end" of the A16 point would make it seem like the PCM can't provide the ground that it should. After all, A16 is probably just an output transistor that opens & closes a circuit to ground; which that ground itself might be open.
Without knowing what year & model & engine, it's hard to be more specific.
OKhonda94
Aug 12, 2012 12:43 AM
greg05
Aug 31, 2009 05:32 PM
evilseth
Mar 21, 2009 10:32 PM
kissbally78
Jan 18, 2009 07:14 PM
jgrizzlebear
Jul 3, 2007 08:24 AM
