ecu help?
Old Aug 28, 2008 | 01:05 AM
01blueaccord's Avatar
Default ecu help?
So if I am showing a check engine light or anything like that.
Where is the ECU located so I can check what its registering.
Car is a 2001 Accord LX I-4
Old Aug 28, 2008 | 02:11 AM
Default RE: ecu help?
Just take your car to autozone and have them read the code. They plug in a scanner in the connector under the steering wheel and will give you the 5-digit code (P####).
Old Aug 28, 2008 | 08:11 AM
cjdm98's Avatar
Or you can invest in a OBDll scanner of your own.. there only around $59 bucks at Advance auto.
Old Aug 28, 2008 | 11:17 AM
if you still are determined to find the ECU(although i dont know how you read the code straight from the ECU). its under the carpet in the passenger footwell
Old Aug 28, 2008 | 02:02 PM
thankyou. There is usually a little screw potentiometer on the side of the ecu. You turn it all the way to the left and it goes into diagnostics mode and the light flashes either on the ecu or your check engine light flashes. Long flashes are for 1st digit and fast flashes are for 2nd digit.
Old Aug 28, 2008 | 06:21 PM
finch13's Avatar
No such thing on your ECU, I gurantee it. There are no mechanical parts involved in it at all. All it is is a circuit board with a ton of processors and some memory.
Old Aug 28, 2008 | 11:59 PM
O, I just thought it would be the same because on my 300 it was also under the passenger footwell and I checked codes that way.
live2rice
Sep 20, 2012 02:26 PM
mamtsberg
Mar 17, 2010 09:15 PM
mbo1985
Oct 19, 2006 12:48 AM
Adie
May 14, 2006 09:17 PM
rhinotechie
Aug 7, 2005 09:45 PM
