Egr cleaning help
Old Apr 24, 2009 | 04:42 PM
budd3
Default Egr cleaning help
1995 accord ex vtech 4 cylinder. I have found 2 sites that explain how to clean the EGR ports. I'm at the point where I have removed the 3 nuts from the fuel rail but it still will not move/ come loose. Whats next?
Thanks
Bud
Old Apr 24, 2009 | 05:18 PM
If the fuel rail is unbolted, it should be able to slide off of the fuel injectors.
There might be some vacuum hoses that you have to remove as well.
Old Apr 24, 2009 | 05:28 PM
budd3
Does the rail ever stick to the fuel injectors?
Old Apr 24, 2009 | 07:12 PM
It should pull loose from the injectors or pull the injectors out of the intake manifold.
The o-rings could stick, but some slight twisting/turning of the fuel rail should loosen the seals.
Old Apr 25, 2009 | 10:31 PM
budd3
A little twistng done the trick. Thanks for your help. Cleaning the ports seems to have fixed a steady speed miss I had.
accordfan222
Jun 1, 2007 08:25 PM
poser_pilot6
Dec 6, 2006 10:40 PM
nixalot
Jun 27, 2006 07:50 PM
deserthonda
Jun 21, 2006 05:18 AM
Antwan
Mar 28, 2006 04:33 AM
